Purge solenoid lines routing
swayzeecrazy915
NC
Hey everyone, new member here! I’ve been working on a head replacement on my beloved 97 Mazda b2300 2.3l (first time doing this). I made the mistake of not taking a lot of pictures when I disassembled it so now I’m struggling putting things back together. I can’t figure out where the hoses coming off the purge solenoid connect... there’s a connection on the bottom of the upper intake that I thought might be part of it but it’s not fitting extremely well, and then does the other side go to the carbon canister? Thanks for any help ??
32259
Ok so I found a piece of hose I was missing that connects the one side to the carbon canister. I’m fairly confident the other end goes to the port under the intake but I can’t figure out where the harness is supposed to bolt to.
I have a 94, the ford manual shows the hose going to the throttle body, but I can't find a connection point. I guess I'll find it when I remove the throttle body to clean it.
