atlgadawg
- Sep 17, 2007
- Automatic
I have a 1996 Ranger with 4.0. Got the P1443 error code and found the threads about that here. The Purge Flow Sensor was definately shorted so I replaced that with a new motorcraft part and also replaced some of the vacuum line that looked bad. Reset code and drove a while and the code came back. Going to check the solenoid next but is there any way to know if the cannister or the PCM is bad?
Thanks
Thanks
