Purge control valve ?
jrqf
Next to the fuel evap canaster is the purge control valve. What triggers this valve to open/close? I have tested it with 12v and it works. This valve not working causes the 1443 code..ThankZ
Purge control valve
I know someone out there knows the answer to my question....I disconected the valve and truck runs fine,just slight ruff idle,and no CL code...ThankZ
There is a ford tsb for this code on your truck 96-6-8
Continuous Diagnostic Trouble Code (DTC) P1443 indicates an Evaporative System Purge Control Valve Flow malfunction.
P1443 Loose, broken, kinked or disconnected fuel vapor return hoses.
Chaffed canister purge solenoid wiring harness (rubbing against power steering bracket). (no-start condition)
Wiring harness chaffed. Broken, bent or pushed out pins on canister purge flow sensor and/or solenoid.
if the solenoid is working, you can try to clean the valve out with carb cleaner etc, clear the code, see if CEL comes back. if it does then replace valve.
