pulls to the side
whitebassbenny
Well I added leveling coils about a 6 months or so ago and had it aligned then and then was told i need the bushings for it. So i had bushing installed onto it and then had it aligned again and now it pulls to the right side some when i take my hands off the wheel. I have to keep my streering wheel turned to the left some to have it go straight. Im just very annoyed that this is happening now. It's a 94 4x4 ext cab with the rough country coils and sky jacker shocks. Any idea why this pulling happens?
I had my U-joints replaced aswell.
I had it done at town fair and the toe is within spece and is green and camber is the same but the caster is off .9* and 1.0* still but the bushing is max.
Improper caster will cause it to pull like that. If the caster can't be aligned properly you may need to drop your radius arms down a bit at the frame.
