Pulled The Codes from the 93! Help?!
Ryannn
Carson City, NV
157 - (R,M) Mass Air Flow signal is/was low or grounded - MAF
172- (R,M) Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
176- (M) Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
Do I just replace all of those? Does it have two 02 Sensors? Whats the deal here?
-Ryan
Sounds like the MAF is bad or dirty,thus causing the lean codes on both banks.
Im getting a New MAF and two new Oxygen sensors tonight so we will see how that goes..
I doubt it is the O2's like I said.
When the MAF readings are shit, you will get lean/rich codes on both banks. You've got lean codes on both banks.
Replace the MAF, disconnect the battery for 10 minutes to reset the KAM and give that a go. Bet your problem is gone.
im with sasquatch, it unlikely both O2 sensors are bad, its probably your MAF
So I got a Reman MAF and a Brand spanking new Optima Deep Cycle Battery today. I disconnect the battery tomorrow.
