project first truck
i got leveling coils in the front and 2 inch blocks inthe rear i have 235 75 r15 tires
the 9004 to 9007 swapp
project first truck
project first truck
project first truck
Saw your avatar. Found this thread. No more pics of your truck to look at. :sad:
i busted out the heavy shit lol
project first truck
this is when i decided to run 4 ga away from the alt and to the battery it was a huge undertaking cause i ripped out all the old 10 ga factory wiring to make the new stuff look clean
old harness
project first truck
more old harness but on the fuse block side
project first truck
puling them back through the loom
project first truck
this is where i took one of the 8 ga wires that i had running off the batt and ran it to one of the alt circuits i had just opened up soooo i had fused power running to my off road light relays
project first truck
organizing the regulator wires one goes where the blue wire went one goes to the pos out on the alt and one goes to switched power
project first truck
project first truck
project first truck
this is running the exciter wire and 4 ga main wire
project first truck
i had to put a fuse in there somehow
project first truck
the red is the alt in the blue is going to the batt to feed it all
project first truck
i moved the ground a little closer shorter cables = more power by lower resistance :headbang:
after doing all this i noticed a big diff with all the loads on :icon_hornsup: way less needle drop :icon_thumby::yahoo:
ahhhh yeas duel batts the bat is an ever start marine/deep-cycle 650 ca
the bracket i welded up real quick out of left over scrap
project first truck
running the wires the bottom breaker controls the on or off of the aux batt
project first truck
project first truck
project first truck
project first truck
cleaned up under the hood blue wire goes to the relay and the whole truck the red goes to the starter
project first truck
project first truck
sett the bat in and connected everything and bam u got power :icon_thumby::yahoo:
project first truck
project first truck
Lookin good man. Out freaking standing work!
ok since my trannys bin out for repair iv bin buissy doing what i do best workin on my truck =] so lots has bin done
iv bin cleaning and spray painting lots of thing 1 cause i dont want them to rust and 2 it looks good:headbang:
project first truck
project first truck
project first truck
project first truck
project first truck
project first truck
project first truck
project first truck
project first truck
if u donate i might decide to not make thiss a paperweight
project first truck
project first truck
