87rusted5oh
Well to start off i was given what was thought to be a good solid truck, with blown 2.0 engine. What turned out is a solid frame and pretty decent bed with the cab floor almost entirely rotted out. So out with the motor, trans and interior. Then to clean everything up. I have already acquired some good parts for the swap. I picked up a 91 F150 5.0, 94 Mustang T5, and an 01 sport trac 8.8 rear end with 3.55's. I need to gather up many other parts so i thought i would ask some veterans on here what you would recommend.
Needs list:
clutch/flywheel
slave cylinder
radiator
drive shaft
motor mounts
headers
And the needed, but already know what i want are GT40 heads, GT40 intake, and custom exhaust. The rear end is sorted out too as far as welding spring perches on.
The truck isn't meant to be a show stopper. Im building it to be a well rounded pickup. I want it to look good, have decent power, and be reliable.
Needs list:
clutch/flywheel
slave cylinder
radiator
drive shaft
motor mounts
headers
