Project 84 Ranger
steering done, seems to work really good and all the joints are tight no slop. Got my trac-bar bracket from Bronco Graveyard, it fits nicely up on the frame with some small mods. On the steering I used drivers side inner and outer tie rods from a RBV and it was the right length around 20". From what i can see comparing the TRE tapers they are all the same, torqued the nuts down and no slop. I tested the steering with the truck running and it steers good, no bind or slop. If i did the steering wrong someone plz let me know before it results in a mechanical failure.
Project 84 Ranger
Project 84 Ranger
I got the angle the best i could with my dropped pitman arm. I had to watch out for engine crossmember clearance so i couldn't move the bar up any more or else it would interfere. Shocks coming up next, and then the test drive.
Project 84 Ranger
Two questions:
How are the 4.10s working out with the 35s ?
Is the cross member getting in the way of the front diff ?
Looking good !
Two questions:
Looking good !
I havent got 35's yet, but i have run the truck 4.10's on 33's and its got plenty of power.
The crossmember dont hit the diff, no problems. Im going to run bumpstops incase i bottom out.
Got the sending unit back and installed into the tank. Put the bed back on and finished lifting the rear. New shocks added, 34" long from a Bronco. Some recent pics on rollers.
Project 84 Ranger
Project 84 Ranger
speechless man. very nice build. i like the 302. sooooo clean of a truck from the rust belt
Thx for the support! Yeah it is a clean truck for the most part. The only bad areas are the doors, im replacing them though. The 302 is the best upgrade ive done, period.
truck is clean, build is clean, everything looks great bro! good job!
