bigspaceghost
Truck is a 95 ranger. Here we go--Truck has low beams-no high beams also no brake lights,but does have running lights. I just put in a new multi problem switch to correct the issues. And same issues are still there. I checked the fuses and did a continuity test on each and they are good. Is there relays that I must check also? and is there any other fuse links that could have crapped out?
