RonD I did a compression test and five were at 155-165 with #1 at only 135 psi. Also ran my scanner again and came up with another code 11. It isn't 'fun' and I'm not certain I got the readings for the MAP sensor with the engine running correct or not. With the + lead of the DVM on the middle wire and the - to ground I was getting variable reading all lower than about 100 hz. I took a couple of videos that I will attempt to attach. ( I did utube video uploads- here are the links; I think !
.... and with the vacuum gauge attached-
