Gwilly65
- Nov 18, 2015
- Automatic
I have a 90' Ford Ranger 4.0l XLT that i just bought for cheap. The previous owner took the engine apart, replaced the heads, injectors, lifters, and all new gaskets. It is put back together now, for the most part, and i am having some issues.
From what I can tell it is leaking transmission fluid from between the engine and tranny. The fluid is verry dark and kind of has a red tint to it. I have read some other forums on the A4LD that says it leaks there alot. is there a cheap way to fix it, or defined way i can tell what it is without taking the trans off?
When i take off the radiator cap or the oil cap after running for maybe five minutes, steam/smoke comes out. when i take the radiator cap off while the truck is running, there is no bubbling. My grandpa who is very good with automotive stuff said that there if it was bubbling it is a clear sign that there is a head gasket problem. I am lost at what to do with the tranny and "smoke". Please help.
