BensRanger
My ford ranger wont start unless I give it gas and then it runs but a little rough and dies sometimes, I have changed the gas filter and spark plugs and new air filter and put in fuel injector cleaner. What should I do next.
when you go to start it if you cycle the key on and off a few times does it start better. (when you do this you are priming the fuelpump) if you have access to a fuel pressure gauge you can do a pressure test at the sharader valve on the fuel rail. do you have any codes. sometimes you could have a code without the cel being onMy ford ranger wont start unless I give it gas and then it runs but a little rough and dies sometimes, I have changed the gas filter and spark plugs and new air filter and put in fuel injector cleaner. What should I do next.
