problem any help ?
chadmilliser
MOIRA NY ( 5 MILES AWAY FROM ) CANADA
i own a 95
I will start by saying I will never take it to another garage again . IM 20 years old and have done beter work on my truck than all the garages ive taken it to . I will make it short and just say last time I took it in for plugs and wires. they only changed the plugs and charged me for both and tryed to tell me the wires were dirty from there oily hands. THEN 1 week later my tire falls off at 60 miles a hour, takes out a fence and cost my ins . 1500.00 bucks. come to find out later they told me they took off the tires to change the plugs . I redid there plug change because they did not gap them and I could get the plugs easy. I should have did it myself the 1st time !
another good garage changed my intake gasket and left me bolt less. Really they lost like 8 bolts and hoped I did not notice.
well the truck runs not right .. a little lack of power and check engine light is on due to a dealer only light that is improper air . I got a new tps and mass air flow meter .The cooliant does not go down that I notice. Im hopping it is not the intake gasket again. It ides fine. The problem it a little lack of power. The heater does not always kick up alot of heat eather. I do not hear no air leaks all I can hear on idol is the lifter lift and it sound louder on the drivers side.
I also took the temp sensor out and spreayed it with mass air flow clear. and let it sit 5 mins i hope this is not the problem .
