65Ford
Hey all- got a m5od and its been catching middle-high so I spec'd out the slave using factory manual. It says if the slave bearing movement from up to fully depressed is over 7.5mm to replace disc and pressure plate; I'm at 10mm. I put all new stuff in there 23k miles ago and disc wear looks great so figuring the fingers of pressure plate are bad; can I just replace pressure plate? Trying to save some cash if possible. TIA-
