Prerunner type stance with 2in leveling kit?
mp3deviant721
Eau Claire, WI
I'm not asking about prerunner suspension. All I'm asking is how I could achieve a prerunner style stance with a leveling kit. What I'm wondering is how can I get the rear end 1in lower. I will be putting on a 1in body lift to keep the rear end at stock height when I lower it so I can fit 31's. So basically, I'm looking to do a 3/0 lift with out lifting actually lifting the front end 3in. I have a 93, if it was a 98 or newer I would just put spindles on it. Or do you guys have better ideas than this? I'm working with a budget so lift kits are out of the question.
Im confused. You want to lower to fit 31's but you are adding a body lift?
what i get is: you are doing a body lift, and still wanna lift the front suspension to get a prerunner stance leaving the rear stock?
then do a BL to keep clearance and just lift the front suspension with a spacer
It sounds confusing. But I am wanting to lower the rear end by one inch. Then I put a leveling kit on the front to raise it two inches. Then put a one inch body lift on it to bring the rear back to stock and have three in the front. So it would be a poor man's 3/0 lift. So I can fit 31's.
ohh ok got it now.
well that can be done, i think if u remove 1 leaf from the leaf packs the rear will lower like u want it to.
you are gunna lose something if you do it that way anyways. you could flip the shackles and then make a custom block to bring the back to where you want it
