Power window regulator spring.
rangerred
I'm replacing the drivers window regulator, as well as the motor, as long as I'm in there.
The helper coil spring is not installed on the regulator, and I would like to know how tight the spring should be. (How many turns on the spindle ?)
Also, I can see this assembly flying apart as I install it. Any tips re that?
Thanks.
