- Aug 6, 2007
- Age
- 37
- Plattsburgh, NY
1999
i picked up a 04 ranger.. long story short i put a motor in it and pretty much gave it to my ole man for christmas.... i got all the little bugs worked out of it except the power window on the pass side.. i thought the motor was bad but its not.. if you put power to the motor, you can get it to go up and down.. the driver side switch doesnt work. and the pass switch is weird.. if you power the window down the switch will move the window in the up position but you have to press DOWN on the button to bring it up.. doesnt do anything the other direction. i swapped both switches.. checked for power and what not.. i cant figure it out... i did try something tho.. i think it was the white/yellow wire. if you ground it. the switch works. but works backwards and the driver switch still doesnt work.. what do you guys think?
