Power steering leak
Speedwagon
My power steering is leaking a little bit where the line goes into the side of the pump. Is there a seal in there that I need to replace, or just take it out and put some teflon tape or something on the threads?
verify the leak a little better so you know what you are dealing with- clean it with Gunk or kerosene and maybe the carwash high pressure spray and let it dry- then run it and watch it close to see whare it is coming from. Then go from there.
