DasBroncon
- Nov 16, 2011
- Automatic
TL;DR: Can a sector shaft adjustment stop a leak? Is it better to replace the box, or rebuild it?
So my steering has been leaking about 2 weeks now. It started when my brakes blew out on the trail because my tires were rubbing the brake lines. I had to steer the truck with the engine off all the way to the trailhead while strapped to another trucks front bumper acting as my brakes. After all that I noticed power steering fluid dripping off my pitman arm, my friend said it was from steering with the engine off and it should go away in a few days or else I will need to replace my steering box. I started reading up on the steering box rebuild. Then a couple days ago I broke down at a gas station for a completely different reason and met a guy who used to have a ranger and he said I should just adjust the sector shaft. He pointed it out to me and told me to loosen it some amount and then tighten the nut on it and back it off some amount but I don't remember what those amounts where. Upon further research here, I couldn't find any threads or articles explaining this process. So I guess I want to know if anyone has ever done that to fix a leak, maybe in addition to using stop-leak, and if not, should I go ahead with the rebuild kit, or is the warranty and simplicity of a full box replacement worth the money.
