cstall77
I 302 swapped my ranger I set the engine as low as possible for various reasons. I'm converting to power steering and the gear box does not fit, and will not without some cutting. My question is if anyone has ever used a bronco power steering box? from the research i've done and the measurements i have it seems as though it will no troubles at all clearance wise but will have to figure a new pitman arm and would be able to eliminate the use of the oil filter relocator as well. If you have swapped your ranger and went from manual to power steering, im intrested in what you think.
