Power mirror upgrade??
Jtrussell1890
Forum Member
💻 TRS Socials
Matagorda
TX - USA
Vehicle
Drive
2WD
2.3 (4 Cylinder)
If you expect the worst and hope for the best, you're already planning for failure.
So on my "wish list" of upgrades to my 96 XLT supercab is powered and possibly heated mirrors. I know that I have found power movement mirrors to upgrade to, but I don't think I have come across the heated mirror upgrade. Has any one else seen these for my generation of Ranger? I'm pretty skilled with electrical, so doing some mods to make it work wouldn't be that much of an issue. Sure would be nice to have that heated feature to assist with defogging during the cooler months.
No; I haven't either.
Have you considered using the heated mirror option that was used on the first-generation trucks?
I just added heated mirrors myself. I used an Explorer radio bezel with the defroster switch and used Ford's diagram and wired it through a GEM. You could bypass the GEM by adding a timer. I used Explorer heated mirror glass because the Explorer mirror frame won't fit the Ranger. I have the 2006+ Ranger mirrors. My 1996 was prewired behind the dash for power mirrors. I had to add the door harnesses from the junkyard and then get the switch and switch door bezel also. I also added power windows and locks. If you look at the connectors behind the kick panels you may find the mirror wires also there, as I did.
Great info. Very much appreciated. Now I have a foundation to start with. Might not be in the nearest of future that I do the mirrors, but now I'm not feeling so blind. Thanks.
Let me know if you need any help. I know you don’t wanna change the bezel since you got that one from me. Ha ha.
You're correct on that. I'll keep in touch when I get ready to start on it
There was a write-up somewhere about doing the Explorer power mirrors with puddle lights and a turn signal mirror glass, but as near as I can tell that glass doesn’t exist for sale anymore.
So after a bit of googling and searching Amazon and a few other places I did manage to find not only the Explorer heated glass replacements, but also heating elements that attach to the back of most standard mirror glass to "add" heating/ defrosting. The aftermarket kit comes with necessary wiring, fuses, switch and 2 elements to do both sides. Now I know where to begin building this part of my project. I am also going to be adding heated seats, keyless entry doors and possibly a rear window defroster.
Very cool! It would be interesting to see pictures of your progress. Good luck!
I know I need to remember to get pics when I do improvements or repairs. I get lost down the rabbit hole and get severe tunnel vision once I start a project lol. I'll try to make sure I get before and after. I did upgrade my instrument cluster to a Sport Trac and sanded down the green on the back so I can get better color transition from the LED lighting.
wait a second. heated seats? you are right up the road from me, we don't need no stinking heated seats (ha ha ha, use the gangster voice saying that).
does it get cooler up there in the winter? i know you are fairly close to houston and houston gets cold.
Cool enough that I like to heat my buns lol
Honestly, the heated seats aren't a necessity, but if I'm going to go to the trouble of putting in the effort to make something of this little monster, I might as well give it all the bells and whistles I can.
To me, heated seats are more about easing back pain than actually warming me. I’ll turn heated seats on with the AC…
