Dave90ranger
Power loss over 3K (Solved)
ok im going to try and explain this as best as possible, ok i have a 1990 ranger 2.9 and any time i go over half throttle over 3K the whole truck stops accelerating and sputters and hesitates. now if i keep it in the same gear and let off the throttle to about a third of the throttle it will start accelerating over 3K and wont hesitate. when i got the truck 3 months ago there was no hesitating and as soon as it got warmer it has been hesitating all the time
i did have a tps code and acs code but i just replaced those sensors without change. i have new plugs, wires, cap and rotor, fuel filter, and new coil. also the fuel pump is new but is starting to make some loud whining that i havnt heard before but idk if that could be the cause or not. i have checked timing and its at 10 tdc and advancing like it should.
im thinking maybe map sensor malfunctioning or possible my fuel pressure. im going to try and check my fuel pressure tomorrow at work to see if its correct. i have thought about compression just havnt has a chance to check that yet either.
