thaefner97
I have a 2011 Ranger sport trim. Today the door locks started acting up. The locks act normally with the fob no matter the scenario. When you try to open the driver door only, both doors try to lock. After this happens while the driver door is open, the lock button on both doors will not function, however the unlock button will. As soon as the door is closed again, both lock buttons function normally. Also when both doors are closed and you press the lock button, the dome light flashes. The dome light will stay on when you hold the lock button in. This is quite possibly the strangest problem I’ve encountered. Not sure if there is some sort of interior control module that could be failing? Any insight would be appreciated.
