Post pics of your stereos
the L7 setup is sick... reverse firing is almost always best. I dont know about that amp placement.. why'd you put it there?
Shortest wiring runs. The ground is the passenger seat mount, power wire comes in through driver footwell, RCA's are only about 2 ft, and speaker wire is approx 2ft as well. I did not want to mount it in the back of the cab (did not want to lose any space, the box with the speaker grill is only about an inch deeper than the factory armrest was). Being an auto with, electric transfer case, and having buckets meant the trans hump is unused space. I have a cover for it when parked. Overall when parked I can pull the rear drawshade and hide the sub, cover the amp, remove the faceplate, and hide the input cable so it looks like no system is in the truck :icon_thumby:
The box is sealed, homemade, edges routered and covered in bedliner. I chopped the factory console to fit around it, and mounted the factory armrest on top with velcro. The armrest is higher than stock, but more comfortable in my opinion. You will also notice a switch mounted on the driver side of the cupholder, I can manually turn the amp/sub off.
You will notice one stupid thing in those pictures, I originally had the fuse mounted inside the truck right in front of the amp. I quickly realized how dumb that was and moved it to within 1ft of the battery.
pfffffffffffffffffffffft..... (brainfart) I posted up in the wrong thread! delete this.
the way the box looks if your looking through the window
2 12" MTX Jackhammers firing down into the floor
This is the head unit I have in my Explorer....
This is is my Ranger....
hooked up to this......
and ending at Infinity subs(sorry no pics).......
Memphis 1100 rms class D amp between the seats
Two Memphis 15-sc10d Subs in a box I made and wrapped in black vinyl
Pioneer headunit and speakers all the way around as well
pic of my old setup
I don't need anything fancy, here my new sploder stereo which will probably go in the Dakota when I sell the sploder.
i have a 10 inch Rockford fosgate and a visonic amp that pushes it very well. and a pioneer head unit. it is amazing what a good sub can do....this one 10 hits way harder than both my interfire 12's put together................does any body elses truck rattle in the xtra cab portion of the cab.....my 1998 2 door has an annoying rattle in there and if i put pressure on the pannel from the outside it stops but i cant find any thing thats rattling in side..it is like between the out side and the inside pannels on that part of the cab.
nothing fancy: 2 10'' JL Audio subs, clarion pro audio 900w amp with a pos kenwood head unit that no longer can play cds heh
