Post a Picture of your lifted BroncoII
74bronco2 do you have a write up or anything about the soft top youve got on that thing? or any info about it at all? that thing is sweet!!!
ts a steel tube frame that clamps to the bedrails like a canopy. The local canvas shop lined the frame and installed a zipper window in the back. the only thin I would and probably will in the future is put side windows for the passengers.
How about some details on the truck itself?
'87 Eddie Bob
2" Skyjacker coils, stock rear OEM wheels w/ 235/75r-15 Treadwright retreads.
'87 BII EB, 5 speed, 3.73 L/S
Dear Lord, 74bronco2 that thing is awesome. Do want specs!
1986 bronco 2
Heres my bronco 2, detroits, 4.56s. emu 6 inch springs, 4 inch shackles, cross over steering, ford 9 inch rear, high pinion 31 spline dana 44 front, billsetins shocks, shock hoops, wrap arm, lengthened 6 inches, 37/13.50 boggers. has 2.9l/5 spd/241 putting 302 EFI c4/205 into it.
Your 37s look small compared to mine:icon_confused: Your truck looks great though....it looks like a red version of mine:D Do your tires rub on the rear fenders when flexed out? I still don't know if mine rub or not, haven't had a lot of time to work on my truck lately.
-Jester
Wow, that thing is tall! How does the little 2.9 like 37's with 4.56's? Mine doesn't overly like 35's in anything but 4lo...
Mild build
I have a mild build on the 2.9, it has intake work done with bigger injected, bored out .40 over with flat top pistons, and a Mild cam
No I have not been able to get the rear tires to rub in the fender, my tires stick out so much because of the Full size running gear, it wont rub in the front when im even flexed out and turning at same time. The EMU springs also ride nice on road and off road even with having alot of arch. it has a wrap arm made of 2 shocks, and helps a little also.
heres mine with a washer lift and 15x10 wheels and 31's
