Possibly a badd ground?
jewalker7842
Tennessee
So the truck was running fine today. Me and the fiance just got back from the store, we go inside for around 15 minutes and we go back out to the truck since I needed to take her home. ANYWAY, I turn the key and instant power loss. NOTHING works. I popped the hood messed around with the negative battery terminal connector and power comes back on. I try to turn it over again, same thing, everything just dies. The starter does not kick in, nothing turns over. The dome light, radio, everything loses power. Now I know I have a failing camshaft syncro and that part will be in tomorrow, but that wouldn't have anything to do with the instant power loss would it? I am thinking maybe I have a bad connection on the battery? I'll mess with it tomorrow after work, but I was wanting your input on what it could possibly be. I'm thinking its a bad ground somewhere. But why would it just die?:icon_confused:
Check the wire from the driver's side back of the block to the firewall. It's a bare wire, probably silver in color and woven in a flat braid. It is the ground connection from the block to the frame. The battery grounds to the engine block. The engine block is isolated from the frame with rubber mounts. If that braided wire has broken or disconnected, or corroded so it's not in contact any more you won't have a complete circuit for the electrical system.
Also, remove and clean both battery terminals.
^ Good advice.
I would strongly suspect the positive cable to the starter itself has internally corroded under the insulation.
I just put BRAND NEW battery leads on the battery a few months ago, but I'll make sure to them them off and clean them anyway. I'll definitely check those ground wires. Thanks for the advice.:icon_thumby:
^ Good advice.
I never would have thought of that one. I will check that also. I'm not very good when it comes to this electrical stuff. I know how current flows, but electrical issues have always been hard to diagnose for me.
Thanks for the advice guys. It will probably be tomorrow morning before I get to it. It's raining over here in Tn, and isn't supposed to clear up till late tonight. I'll keep y'all updated. At least I know where to start looking. Thanks!:D
I went out and messed with it a little tonight. It seems the battery leads were a little loose. All seems to be working again. Thanks for the help guys.
