Possible to adapt 6 prong dimmer with 4 prong harness?
justinae
15+ Year Member
Portland, OR
My 1996 has a 6 prong dimmer switch that went bad. Got a 4 prong (and harness tail) that came with a bezel from a 1999. Is there any way to make them compatible since they mount the same?
What wire colors do you have on each one?
For example;
1996
LG/O​
T/O​
R/Bk​
Bk​
Lb/R​
Bk/Lb​
1999
BN​
R/Bk​
Bk​
Lb/R​
Here are the two harnesses together.
OEM 6 Prong
LG/O
Bk/Pink
T/O
LB/R (2 of them together)
R/Bk
4 Prong
LG/O
Br (2 of them together)
Bk/Pink
LB/R
i was hoping to figure it out with the Explorer wiring diagrams I have for those 2 years. But your 4 wire plug doesn't match up with my 1999 diagram at all. Even if you can use the 4-wire dimmer module, you would then need a separate switch for the Dome Light/Courtesy lights circuit (LG/O & Bk/PK). We need the exact Ranger wiring diagrams for those 2 model years.
However, check the part # of the 6-wire dimmer you need. There is a used one from a 96 Explorer right here, if you want it for shipping cost. I didn't play with it much before disassembling the truck. The instrument lighting worked. So, I'm pretty sure it's good. It should plug directly to your wiring.
Upcoming TRS Events
Featured Ranger Based Vehicle
