titanmax
- Feb 18, 2008
- Age
- 45
Need help with possible overheating issue.
I have been dealing with a cooling problem in which my temp gauge seems to read that the coolant is rising and overheating during extended periods of operation, i.e. over 15 minutes of driving.
At first because the gauge seemed to read a spike in temp and then it would drop I parked the truck on a hill and took the cap off and ran the truck for like 30 minutes or so to make sure there weren't any air pockets. gauge stable whole time.
The top hose the returns coolant to radiator heats up and gets hot when I was checking for air pockets also.
Even after this I had the same problem so I proceeded to replace the temp sending unit itself. Problem still there.
I thought it might be a head gasket that was leaking but there was no white smoke from burning coolant, there was also no coolant that appeared to be in the oil and a block test I did just came back negative.
There are no visible leaks and Im thinking that my next course of action will be to put on a new external water temp sensor at the return hose to monitor the actual temperature.
Thanks,
Max
93 Ranger 4.0
Thanks,
Max
93 Ranger 4.0
