posi??
Crazythingsido2
07/2009 & 04/2012 STOTM Winner
MTOTM Winner
Va
i have an 86 2wd ranger and i want less of a limited slip. i want it to stop spinning only one tire. so is there a diffrent rear end that i can go with that will be the same width, or what type of gears can i put in the rear end??
thanks
will stronger axel shafts help that.
thanks but is that my only option
Or a detroit locker that's more expensive and harder to install. Or an axle swap for an 8.8 so you have more choices in lockers but it dies not matter what you do, you're going to spend money.
yea but is the 8.8 wider
Depends on the year and what you pull it out of.
all the 8.8 has is a diffrent splin and bigger brakes right?
Info:
i have an 86 2wd ranger and i want less of a limited slip. i want it to stop spinning only one tire. so is there a diffrent rear end that i can go with that will be the same width, or what type of gears can i put in the rear end??thanks
:icon_confused:What gears you got & your location would be nice!
3.73 i think
im in va
this is my truck
posi??
Find yourself an 8.8" out of any '90-'92 4.0L Ranger with the stock Traction-Lok L/S. Same exact width as your stock axle, and should eliminate that one-wheel-peel (you can repack the L/S clutches to make it grip even tighter if you want as well). Except for possibly having to swap your driveshaft (or modify the pinion flange), it bolts right in.
