97RangerXLT
Forum Staff Member
💻 TRS Socials
TRS 25th Anniversary
GMRS Radio License
- Sep 18, 2007
- Anderson, IN
- State - Country
- IN - USA
- Other
- 2020 Ford Edge Titanium
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Automatic
- Total Lift
- 2"
- Tire Size
- 31"
um your point on the universal 5 lugs is completely not relevant to the issue. the universal 5 lug rims have the holes set up so that there is *no* side or sheer force on the studs because those wheels when torqued down the force pulls straight out on the stud like it should, and they can be properly torqued.
As for killing a bus load of nuns, doubtful that would happen in any case unless you steer your rig right into it (providing a bus of nuns was conveniently sitting out where you are wheeling) and and throw Molotov cocktails through the windows and yell "allahu ackbar"... However I think that unlikely since you are active military
My point is not that you would get killed or kill someone else or even kill cute bunnies and squirrels but that the wrong size, even .7mm off, will put a force on the lug studs that they were not designed to take. This will not be an issue right away, but down the road a bit. more than likely you will not lose a wheel, but it is more likely if you hit something hard while wheeling.
AJ
AJ
