PlumCrazy's OG Build
guess that makes sense did u use pipe or solid steel
2.5" 1/4 wall tubing welded to the bottom of the original coil "seat" (the stepped metal peice with the plastic insulator on it)
wow this thread is on page 14.lol
and this is my 700th post:D
Get to your first thousand and you'll become a post whore.
1.4 posts per day. I have been a member for almost a year and a half.lol I spend a lot more time reading and than I do posting.
I decided to put the 02 tails on. I didnt like the look of the amber.
Next step is putting LEDs in them.
-plumcrazy
how hard was it to wire these lights up
Just wired them like trailer lights off the 4 flat.
Thanks Crawlin.
I snapped a few pics of my switch panel. The buttons are all push on push again to turn off.
I am forsure stealing this idea if it's alright with you! :icon_thumby: That's a sweet place to mount your switches, I'm impressed!
Edit: That's the conversion plate for an aftermarket deck right? Did you just cut out the hole part of it and mount the plastic plate to it?
I just cut the cuby hole out and mounted my switch panel over it. I used some extra screws and caps that I had left over from my gauge pod. The caps over the screws give it a nice clean look.
i am probably gonna steal the switch idea too , and how did you figure out where wxactly to cut the hole in your floor for the t-case shifter ? and do you have a pic of how you rewired it from electric to manual shift t case ?
I removed the plate in the floor and measured where the tcase shifter was in relation to the four bolts that hold the plate on. Then I cut a 1.25" X 4" hole.
There are pics a couple pages back on pg 9 that show which wires I used. Just cut them and connect the wires from the cluster to the wires on the tcase.
I decided to spray all the salt residue off the truck, an when I came out like 2 hrs later I found this. Apparently when I power washed the wheels some water got under the covers and froze which split the covers.:annoyed:
So while I had the lug nuts off to replace them I noticed the front rotors seemed a little loose. I pulled the hubs off to find that the spindle nuts had backed off a little.(no big surprise it has been 10,000 miles since I put the new bearings in). I was tired of fighting the stupid little nub on the lock washer, so I welded a little on the end of the nub and filled it square. Now it sits down in the key-way with no worries of it slipping out when I tighten the outer nut.
We had a little snow storm and my boss asked me to plow the lot at work, but it was 10 degrees and the F-350 (diesel) hasnt been started in a couple weeks and I didnt have time to wait on the block heater to do its job so I improvised.
I am surprised how well it pulled and that I could stop on a dime. The Bobcat weighs more than the truck and the trailer weighs another 1500.lol It hardly made the truck squat, gotta love those Chevy leaves.
Another fog light burnt out so I decided to go another route this time. They are low wattage yellow bulbs. I like the look, I wish the yellow was deeper but I cant complain since both bulbs were less than 10 bucks.
When I fixed the cabmounts a while back it raised the rear of the cab like .25-.50 so I had to shim the front of the bed up to make the body lines match, but I was too lazy to shim the rear of the bed so it looks like it is tilted back a little.lol
