PlumCrazy's Build
2 and 3 of 7...
ARP studs for carrier bearings in both axles
PlumCrazy's Build
8.8 install kit and cross pin bolt.
PlumCrazy's Build
Sent from XT907 using Crapatalk
4 and 5 of 7....
Wheel bearings, and inner axle seals. One wheel seal is MIA?
PlumCrazy's Build
Picked up tcase off Brad last weekend. Going to see if I can fix my manual case with electric case parts again.
PlumCrazy's Build
What are those big weights for that they put on the back of the transfer case and rear axle???
Robert
posted using a red lipstick and gun power.
Vibration dampeners.
I don't have one. I used the mounting holes for the doubler mount.
Box 6 of 7 showed up..
PlumCrazy's Build
Only things I need to get my hands on now are spindles, rotors, pads, and caliper brackets
Past that mark months ago...lol
I still don't think I have a lead foot (maybe a brass foot)..I have seen a lot worse.
Working 60s Mon-Fri .....and its harvest time soooo my evenings and weekends are spent running the combine or hauling corn/beans.
Still working on moving in/finishing up the interior of the house. Kitchen remodel will wait till spring summer.
Garage is almost cleaned out...PO left all sorts of junk when they moved to a retirement home in FL.
I did haul the Ranger here and shove it in the garage tonight though. I need to get the 220 outlets wired up and replace the chimney pipe on the wood burner before the garage is ready for winter projects.
It needs some better like lighting and a decent air compressor too...but its a nice setup over all.
I need a winter beater too....I need to win the lottery and I'll be set for a while.
Dark shitty picture...but the blue turd is a garage queen now...
PlumCrazy's Build
