Please tell what you think about these parts
BlueLighting1999
Des Monines,WA
I want to lift my truck a little bit more.... So i was thinking of these parts to get a 2 in lift n the front 3 in lif tin the back and then something to get better handing...
Front of Truck:Ready Lift Front Torsio Key-2in lift
Rear of Truck:Febtech rear suspension block-2in lift
Trailmaster rear add-a-leaf:1-2in lift
Hellwig Frontsway bar kit-Hammertone-Better handing
Is there any leveling kit for my truck???
Also you can look up all of these parts at Carpartswholesale.com Look up 1999 Ford Ranger 3.0L 4WD
No no no NO torsion keys!!! Useless junk that is nothing but a waste of your money.
Crank your stock keys and save youself the money.
Rather than the block install Belltech 6400 shackles.
Get it aligned and call it a day. Any more height than that, get a bodylift or spend the $$$ for the superlift.
Edit: I see you have it cranked already and have the body lift, that is as much as you are going to get out of it without stepping it up to the superlift.
So what about those Shackles? They will lift the back correct?
What about add-A-Leaf????
Also what about that sway bar? Because i saved up money for a money nd slod shit so im spending alot of money on my engine but some on my suspention! ANd i need to get like $180 saved for my new cowboy hat and Tim McGraw tickets!:icon_thumby:
The shackles will lift the back 1.5-1.75" and will improve the ride and flex of the rear suspension, where as an add-a-leaf just tend to be stiff and harsh riding. I would not stack another block ontop of the factory one either.
The shackles can be had for under $60.00
Can't say about the sway bar, never had any personal experience with one of those, but if it is bigger than the stock one it should improve the bodyroll/ handling a bit.
Okay man thanks! Would the Shackles incress my payload??? That is why i want to had a leaf.
Okay then i will see then about the sway bar
autozone sell the shackles for like $30 :headbang: and no they dont and neither does an add-a-leaf, it just stiffens the suspension and makes the rider firmer, but i guess it could just a little maybe
Yeah your about as far as you want to go weith lifting it without going to a true suspension kit. The only thing I would see you being able to use is the shackels but why would you want to lift the rear more?
Also a sway bar is just a waste of money if you ask me, your lifting it and putting bigger tires on it so the body role is going to increase with or without the sway bar.
