Okay here is the thinnest one in the pack. And none of them are stuck together. Damn you Motive... =(
i have done dumber shit.
(dont tell anybody)
.011"
.001 is the very first tick.
Okay so I wasn't being a total idiot then. Thanks for the reassurance.
Anybody know of an install kit that they know comes with much thinner shims?
I don't know if they come in much thinner shims, but you should get more of an assortment. Like I mentioned earlier, I used 2 shims that totaled .028". My thinnest of shims mic'd out to .007" or so. Spread out your shims and organize them into piles according to thickness. Stack shims together to get roughly .030". Go from there.
OR, find a local R&P shop and ask for some shims, they should only be a few bucks if even free. They normally give you a bazillion in each kit. They probably have stacks upon stacks.
But at any rate, I've been pleased at the assortment my Yukon kit gave me.
I'd maybe try .010" backlash on it, see what that looks like.
If your coast pattern doesn't smooth out a little (looks a bit heavy at the bottom), maybe also move the pinion out .002" or so (.002" thinner shim stack).
Having a pattern that's toward the toe is better than having it close to the heel though (under load, gear deflection tends to push the contact more toward the heel).
