Please settle this question
I won't be surprised if you don't find a solenoid or other type of electrical valve. My '89 has nothing but hard plastic and rubber tubing from the canister to the throttle body, and I am also the original owner. PCV tube is routed to the same area. Some of the years may have had check valves to keep the gas fumes in the canister until the engine was running, but these years didn't have electronic purge valves operated by the computer. One of the photos looks like it could be a vacuum operated valve. I don't have one of those either.
If you still have the emissions sticker on the core support near the hood latch you may may be able to show the emissions tech the vacuum diagram and convince them these early rangers did not have purge valves.
If you have the 1983-1992 Ranger and BII Haynes manual, check out section 6.6. Third paragraph reads as follows. "Vapor trapped in the gas tank is vented through a valve in the top of the tank. From the valve, the vapor is routed through a single line to a charcoal canister located ... near the radiator, where it's stored until the next time the engine is started. When the engine is started, the vapors are routed to the carburetor or FI system, to be burned in the engine." No mention of a purge valve.
The emissions technician said the failure is confined to the fuel evaporative system anywhere from gas tank to charcoal canister in engine bay.
I visually inspected this entire segment, including top gas tank connection points, and the only thing I found so far was cracks in the rubber fuel tank filler neck.
This means the evap system is leaking. They crimp the hose from the canister to the throttle body, pressurize the tank with a special gas cap and then check if the pressure holds. If it doesn't hold pressure you fail the test. The cracks in the filler tube could be the problem. You can sometimes pinpoint the leak by sniffing through a hose and putting the other end up to the lines and fittings.
Thanks Longbed also for your responses
I looked over the fuel evaporative system including the engine bay again today, I addition, I looked under the truck in the area of the fuel tank. I still see no evidence of my truck ever having a vapor canister purge/valve solenoid.
I installed the new fuel tank filler neck today. I'll wait a little bit longer to see if I can rig up some type of low psi
vapor leak test before I replace anything else.
I attached a photo from my engine bay. See that 90 degree turn rubber elbow on top of my vapor canister? I'd like to replace that also due to old age. Any idea where I can buy that?
Just use 2 pieces and plastic elbow like the other line in that picture.
I see what you're saying. Use the hard plastic elbow. (not curved elbow)
Both ends are different diameters. Looking online. Didn't find anything yet
I broke that plastic elbow while trying to replace the lines on my truck. Had to super glue it together to get the smog check done. It looks like someone has already replaced your evap hoses with fuel line hoses. The evap line is more pliable, probably the same material the elbow tube is made of. I could not find it locally and haven't done a wider search for it yet. You'll probably have a hard time finding non-standard pieces like the two-size plastic elbow. Here's a bunch of Dorman vacuum lines and fittings on Amazon. That might have a replacement for the rubber elbow. You'll have to improvise. My leak was down by the fuel filter where the line changes from flexible tubing (I think the fuel line, return line and the evap line are all one piece) to the hard plastic line that runs into the engine bay. I rigged up something with gas line to join the two without leaking.
I had a thought after sending my posts last night. Did your smog technician know enough to crimp the line to the TB? The way you described the problem as "anywhere from gas tank to charcoal canister" suggest s/he did, but if they didn't because it's not needed when there's a purge valve, that would explain why the system won't hold pressure. My smog tech has these locking pliers that look like sheet metal snips, long handles so it can reach into tight places.
I installed a new charcoal canister and that fuel line hose back in 2017. I liked that fuel line hose because it is more rugged and durable then the regular evap hose.
The smog tech seemed uncertain and he had to consult with the shop supervisor. They were both looking at the engine bay and the supervisor seemed to be
explaining something to the tech. Maybe the subject was the absence of the purge valve solenoid.
I think I'll drop an email to Dept of Environmental Quality tonight after work. I'll give them information from inspection report and ask them to check if test was done correctly.
So if I am understanding you correctly, you're saying if they did not crimp the line, it would cause a false test failure?
As I understand the evap system on our generation of Rangers and how the test works, yes. The pressure would go into the TB and then likely out the air cleaner box. (Another thought I had on this subject is that MAF vehicles may need to have a purge valve so the computer knows when air is coming in from the canister but with MAP it doesn't so long as the air is coming in through the TB.) My smog tech guy is really nice and we moved that crimper to a few different places to determine if the leak was near the tank or near the canister. So I think the system won't hold pressure without a hose crimped. The gas line hose is very diffcult to crimp shut. I think we had to switch to a vice grips to do that, so if you changed the hose to the TB, not getting it crimped shut is another posible issue. It's not easy to reach but you could pull that hose off the TB and plug it for the test. Assuming the canister doesn't have a check valve, that may be an easier place for you to pressurize your system from. I doubt they use very high pressure, that might damage something. The gas cap is also suppose to seal the system. They test that separately.
Thanks Longbed. I will email that state agency so they can ask the shop supervisor how the test was done.
Cheap bicycle tire pump. I might still have one at home. Worth a try.
I believe there is a way to do my own vapor leak test using smoke or bubbles, without buying a smoke machine.
Where do I disconnect the fuel evaporative system do this......at different locations ?
I was experimenting with my air compressor last night. I have an accessory kit which includes a blow gun.
The blow gun handle is more or less variable, allowing you to control the pressure by how much you press the handle.
I think I can guesstimate 5psi or whatever amount they use for a smoke test by looking for an appropriate drop in tool psi gauge.
I was able to get a very low air pressure out of that blow gun last night. I don't know if it will work. But I can try it this weekend by starting with the soap bubbles method
what does the veci label indicate? that is the key. if there is a purge valve it will be on there.
this style system can not monitor psi. testing would be specific to just the lines and tank and sub 1.5 vac or psi. i think there is an issue with the techs abilities to comprehend what the fundamentals are here and this does not apply to obd1 application or there is something overlooked in the laws.
if what you indicate is true, you either have a check valve only or you shitcanned the valve when you replaced the cannister on accident, some of them are on the can elbow. with a 92 i would suspect a valve for sure. there are several rpo connectors that will be hanging around with these things during this era....like the 4.0 will have the wiring for a bap or map sensor or cam sensor but no sensor ....or for the purge valve but no purge valve. might not have the componant....but that connector will be present.
you not finding the connector is a definite mystery. need more detailed photos, it may be taped off in the harness.
these systems are simple.
Hey Bobbie,
Thanks for reminding me to check the VECI label. I just checked it. There is a simple map of my fuel evaporative system next to the label. There is no mention of a vapor canister purge valve solenoid.
With this and the responses in this discussion, my truck did not come with this part. I'm positive I didn't cut off any such part.
I've checked 4 times now.
I also sent an email to a manager at Dept of Environmental Quality. He will check to see if the test was conducted properly and if crimping was included or needed. I am waiting for an answer on that.
Hey Bobbie,
Thanks for reminding to check the VECI label. I just checked it. There is a simple map of my fuel evaporative system next to the label. There is no mention of a vapor canister purge valve solenoid.
that is what i mean, they should have been running off of the veci....
i think they fawked up. get us a picture of the veci when possible
Could be Bobby.
When this inspection is resolved....I am going to present all of this as an argument to exempt these older vehicles from emission testing.
Not only that, replacement parts are becoming harder to find.
I'll be contacting state officials and whomever is assigned this topic in the state legislature.
Enough of this. It's not worth the hassle it causes for citizens.
