quite a while ago i replaced the timing belt on my 89 2.3l and ended up breaking the crank sensor.
the truck was sitting in the yard for a few months and then i put a new crank sensor on it and it fired right up.
BUT
the problem is it won't idle and it backfires BAD and then stalls, completely un-drivable
i checked the timing 3 times its all lined up. put a timing light on it the timing fluctuates between 25-30 degrees ADVANCE to 5 degrees RETARD then i ended up unplugging the SPOUT connector (putting it into base timing mode)
which made it run nice and smooth at a constant 10 degrees advance.
i put the crank sensor on a lab scope and the waveform looked good until plugging the SPOUT back in and then it went crazy which made it stall.
tried a used DIS module from the junkyard.. no change.. tried unplugging the alternator RAN PERFECT.. CAN'T FIGURE OUT WHY!! it never did this before that sensor broke. all i can think of is interference from the alternator, but it runs fine if i unplug the SPOUT or the alternator.
i've been driving it around like this for about 6 months now. can't figure it out
ITS DRIVING ME CRAZY, INSANE LACK OF POWER AND HORRIBLE MILEAGE
PLEASE HELP.
nobody seems to have any idea
BUT
PLEASE HELP.
