please help
jt88bronco2
truck starts but bogs down when pushing gas pedal. Just replaced inertia switch because the connection on the last one got fried due to a wire that got too hot. when i put the new inertia switch in, the red/black wire is still hot and the truck starts but bogs as soon as you touch the gas. any suggestions and ideas to fix this problem. I replaced the fuel pump(not the one in the tank) a couple months ago. let me know what ya think, thanks alot everyone
If the wire are getting hot?? can't be good
check grounds...fused links in wires and relays
what is your alternator putting out??
as far as the engine bogg'n down..check your TFI (aka as the ingnition module)
fuel filter.
is your intake pretty carboned up?
