bambino
- Jun 16, 2011
- Automatic
Hello all,
I have an 88 2.9 Bii. Been having lots of problems with stalling...
Heres what I have replaced....
Wires and Plugs
TFI Module
Starter Solenoid
Coil
Battery
Cleaned the Iac and throttle body
So the problem is a bit weird. When the truck gets to Temp it will stall out when put into reverse or drive. But then will start right back up and idle fine. I seem to hear a slight "miss" while at idle.....
I ran the self test and it told me my TPS is bad so I have one on order....
Based on my track record, I'm not confident that this is going to solve my problems....
Any other ideas?
I am also replacing the fuel filter in the newt few days.....
I should also mention while running KOER test I put the brake to the floor and my drivers side front brake line exploded!
I have checked as good as I could for vacum leaks and found none....
There was another code I found, I think it was EVP or something? Have no idea what that is.
Can anyone help me out? I'm ready to smash the windows out of this thing!
Wires and Plugs
TFI Module
Starter Solenoid
Coil
Battery
Any other ideas?
