Please help! clutch line RECONNECT!!
jchammbone
So hello all,
I am trying to figure out if I done something wrong or not....
Had to remove my tranny when i replaced my motor (88 2.3 mazda tranny)
With all you guys help i got the clutch line removed, no problem. BUT now i can't get the ting hooked back up. It is "locked" "stuck" there but it leaks now and i don't know if I have it together correctly. Is there a o-ring or something that possible fell out that I missed??? Please help
And no I didnt buy new clutch or slave cylinder. I just replaced my motor with a "new" one.
Thanks!! Justin
there is an o ring on the end of the clutch line. the only way to check it is to disconnect the line. there is a grove in the end the o ring sits in.
Ok... thanks so much i will check it out.
Justin
