Please Help 14" to 16"
knucksfirst
Ontario, Canada
OK im going home for the holidays and I need winter tires BAD!! Or ill end p hitting the ditch 100% no 4x4 soo. I found some second hnd tires with rims.. the bolt pattern fits and eveything there just big!! They are 205/60R16.... Is that going to fit in my wheel well with no rubbing while im steering? I have a stock mazda b4000 with no lift. Thanks guys I appreciate it very much.
What size tires came on your truck? Being a 1991 4x2 they should be either 195/70/14 or 215/70/14, which means the tires would be 24.8" or 25.9" tall, respectively. The 205/60/16 tires are 25.7" tall. That is basically a perfect match in height for the bigger stock size, and 3.5% taller than the smaller factory tires.
Either way, those 16" tires are a pretty good match based on height. As strvgr said, backspacing could be an issue, but if the spacing is close, those wheels and tires should be a good choice.
Want to know how to calculate tire size?
(tire width) / 25.4 = Y
Y x (aspect ratio) x .02 = Z
Z + (wheel size) = tire diameter
So...
205 / 25.4 = 8.07" (this is the width of the tire)
8.07" x 60 x .02 = 9.68" (this is the height of both sidewalls)
9.68" + 16" = 25.68" tall
