lowspeedpursuit
So this doesn't really go in here, because I don't think it's engine-specific, but it also doesn't seem to go anywhere else.
I'm doing the fuel pump on my '94, and I feel like I'm taking crazy pills. I bought the Delphi HP10141. It comes with some kind of tabbed metal ring that isn't part of my old setup and doesn't seem like it would fit anywhere. It also comes with a replacement o-ring seal that's slightly smaller (<1/4" difference) in diameter than my old one. If the o-ring slid over a lip it would stretch into place just fine, but it doesn't. It just sits there. There's no lip on either the tank or the pump assembly, and the new o-ring definitely wouldn't seal.
It seems to me like there must be two different styles of lock rings on these trucks? The metal lock ring I was sent, which takes a slightly smaller seal, and the plastic lock ring I have, which takes a slightly larger one. Search is turning up Dorman 55817, which looks like what I want, but I'd like to be able to confirm. I'm finding negative information about this discrepancy, or any way I might be able to come up with the right seal urgently, in real life, today. The people at all the parts stores are also pulling up the metal ring and looking at me like I have three heads.
Thanks in advance.
EDIT: So the Dorman part seems to be listed as fitting '98-'05, which I guess might raise the possibility that someone swapped my truck's fuel tank, except that my '95 parts truck looks just like mine, as does, for example, this guy's.
Thanks in advance.
