- Aug 6, 2007
- Age
- 38
- Plattsburgh, NY
1999
- Manual
can this be changed by the do it yourself guy? i pretty much do all my own work to my vehicle but this is one area iam a bit skeptical about. my front/rear pinion seals are leaking an so is my pops rear pinion seal. mine was weeping for a while then it just all of a sudden stoped. i think its probably low on fluid.i just swapped axles last summer an the seals were alright. replaced the bearings an axle shaft seals as well.. basically bought the axle an rebuild the hole thing. well one axle shaft seal is leaking as is the pinion seal. are any special tools required to change these? what should i look out for?
