M5OD
- Jun 6, 2014
2000 3.0, pings under moderate loads at any RPM (downshifting to 3,000 RPM makes little difference). 77,000 miles and pretty much all original as far as I can tell. I've been running mid-grade gas (89 octane) and it's better, but still totally unacceptable.
If I wanted to actually haul a moderate trailer I think it'd ping at any slight incline. I cleaned MAF, should I replace upstream O2 sensors? I've heard that the OEM coil-pack had something to do with it, but that makes no sense to me as weak fire would not cause pinging or change timing. There are no vacuum leaks or trouble codes.
I just don't want to throw parts at it, and I don't have access to a live data scan tool anymore.
Overdrive!
Overdrive!
