- Jan 30, 2008
- Manual
I've got an 01 3.0 and I hear pinging witht these engines is common, what I want to know is how do I reduce it and or eliminate it
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
its well taken care of as far as maintenance goes and I only use shell vpower the 91 octane so fuel isn't the culprit
The K&N filter you are using MIGHT PASS a lot of dirt and oil.
well, since you arent using crappy fuel, it leaves the stock timing to be the culprit. if you had a distributor vehicle, you could adjust the timing so you dont ping anymore. that worked on my 2.9. since you have a coil pack. you'd need to have the computer reprogrammed witha new spark curve so that it wont ping.
fixed it
whoa whoa whoa! the truck was running and not pinging with that timing curve when it left the factory why on EARTH would he have to have it retuned now? there should be absolutely no reason why he cant run 87 octane and the factory reccomended spark advance with no pinging. if he cant, then something needs to be repaired or replaced...not covered up with band-aids.
carbon build up is a very likely culprit. hitting the motor with seafoam is your best bet...but in extreme cases, opening the engine is your only option. lean conditions can also cause pinging. the 3.0 is injectorly challenged from the factory as it is. things like a weak fuel pump, pressure regulator, or clogged injectors or filters will cause it to starve and ping. vacuum leaks can also cause lean conditions.
