1984ranger28
Hi, Im currently replacing the oil pan gasket and pump, and the pickup tube seems like it has a hidden bolt somewhere. Can anyone tell me where this is? Thanks, Lucas
Look at your main bearing caps. Usually one of those bolts has a piggyback stud for a nut that holds the oil pickup tube.
I see what your talking about. Should I take the nut off main bearing cap? Or is there another bolt/nut that I'm not seeing? Thanks
Do you have any more room to jack the engine up?
Even with the pickup tube off there isn't always enough space, especially on a 4x4, to get the oil pan out with the engine in.
