Picking an Subwoofer amp
Well boss amps have a good range of amps in the $100 and under. It would be nice to have a monoblock to simplify wiring. The power ratings don't seem bad either. Though I think I still want to get a Kicker sub. Everything I have read on them says they can take most anything you throw at them. Guess I have some more researching to do. No plans are ever set in stone.
It only takes an extra 2" of wire to turn a bridgable 2-channel into a mono, so don't get turned away by a 2-channel. Just make sure it's bridgable if that's what you're planning to do.
Honestly, I've never heard a louder sub before for what little room it takes up. It's every bit as loud as 2x 12's and I still have most of my backseat. It's super-loud on the long rumbles and hits extremely crisp in the fast stuff. It also looks WAY cooler than pretty much any other sub too. I started with my amp gain up about halfway when I first installed the sub, and over time it just gets louder and louder as it breaks in. I've turned the gain clear down to about 1/4 on the amp.
Here's the first setup I had. Dual Rockford 12's, the 900W Anniversary amp, and Godzilla independent ported boxes.
Then those got stolen right out of a freakin' parking garage. I barely got them in taking the front seats out, so I haven't a clue how they managed to get the things out in one piece. Thankfully one amp channel was shot, the head had quit spitting CD's, and one sub cone was damaged. They really didn't get much in the steal. Replaced them with this Kicker 10" L7 Solobaric and Boss GT580 1000W amp in a sealed enclosure. Love it. And, obviously, I can put stuff in the backseat again.
Excuse the Taco Bell and random tools! :headbang:
That set up looks nice. I would love to go with an 10in L7:drool: but I could only afford it if I got it off ebay or find a refurbished unit. the ebay ones are probably refurbished anyway. What size is your box? Looks a little shy of 1 cu.ft. The box I want to build has to be able to be cover by the pull cover in the back. Also I plan on putting it behind the divers seat or maybe I'll put it in the center. I may just put the sub off a little longer and get the L7. Is your L7 a DVC 2 or 4. Just wondering because if I get the L7 then I will probably go with the same amp you have. I'll do a draw up of a box that fits the Kicker specs for a sealed box. Should leave a lot of space in the back.
The sub is the 2-ohm DVC, wired in series to get 4ohms to match the amp. The box I got from SonicElectronix - it was $30 shipped and everything. It's like .88cu I'm pretty sure. I'll be moving mine over behind the driver's seat so that I can put the passenger jumpseat back in the back. The sub is DEFINITELY worth the money. I love it to death.
sounds like you dont know how to properly set the gain. you dont just turn it up and down like a volume knob. youre supposed to set it so it matches the voltage coming from your deck. ill give you an example. here are my amp specs:
4x65@4ohms
4x100@2ohms
2x150@4ohms
on my front channels im running a component set at 2 ohms. thats 100 watts a channel. now id multiply 100(watts) by 2(ohms) which gives me 200. then you find the squareroot of 200 which is 14.14. 14.14 is the voltage i need to set the gains for those channels. that may be why youve had problems with rf amps. here a page where you can read up:
http://www.icixsound.com/vb/showthread.php?t=27819&highlight=tutorial
4x65@4ohms
4x100@2ohms
2x150@4ohms
As is how I started. But when the sub was far louder than the rest of the speaker output and all I could hear was huge bass, I turned it down.
Here is the list of the set up I think I will go with:
Head unit:
Pioneer DEH-2000MP
http://www.sonicelectronix.com/item_10753_Pioneer+DEH-2000MP.html
Plan on dumping most of my mp3's on 1 or 2 cds
Speakers:
Pioneer TS-A6871R 6x8
http://www.sonicelectronix.com/item_6621_Pioneer+TS-A6871R.html
Sub:
Kicker Solo-Baric L5 10" 2ohm DVC:
http://www.sonicelectronix.com/item_6504_--+SPECIAL+--+Kicker+06S10L52+Solo-Baric+L5+Series.html
I decided I don't need all the power the L7 has.
Amp:
Boss CX1100M:
http://www.sonicelectronix.com/item_11591_Boss+CX1100M.html
There may be other amp options but this seems to fit best.
All in all it will cost me around $450 with the shipping costs. The HU and speakers first and then I'll get the sub and amp.
Thanks for all the help,
Steven
I thought of a couple more questions came up and I can't find the answers when I look for them.
Do I need a capacitor?
I think I will need a new battery at least. Which one should I get?
What gauge wire should I use for the amp to sub connection?
I was thinking 12 gauge.
nope, dont need a capacitor. your stock battery should be fine also. ive seen systems with about 1500 watts on their stock batteries. no need to fix a problem that hasnt arrised yet. if you even do have a problem id go for the big 3 first, then a new battery and followed by a HO alternator. but i seriously doubt youll have a problem.
im not very familiar with boss amps, so im not sure if theyll put out their rated power. if it does put out 500 watts id go for a 4awg kit. if you know for a fact it wont put out more than 400 then you can get away with an 8awg. 10 and 12awg is just way too small.
Those pioneer speakers will be fine. don't expect any bass out them though. for the best sound out of those speakers, put them on their own amp.
Well the whole reason for the sub is to make bass. Though I might amp them latter. I realize now that I want the bass that a sub puts out. I am tempted to try this box to assist in the bass production:
http://www.sonicelectronix.com/item_7500_Sonic+Sub+Box-+1SVK10.html
It will maximize the room behind the driver's seat and if I mount it right I should be able to have the amp on the floor under it. I plan on raising it up to level of that shelf or whatever it is in the back. Does anybody know why that is there anyways?
I kind of want to see how it compares to my friend's Dual Audio 1100w Bandpass.
if your gonna go with that slot ported box make sure your amp has a subsonic filter or run an inline ssf between the amp and the sub
Well scratch the ported box. I redid the measurements and it won't fit. I think I'll just stick to building my own sealed box. I have a few different ideas and need to decide what will work and look best. The problem is is that I keep coming up with other designs and how they will mount. Also I am going with the dual 4 ohm voice coil wired in parallel so I can get the amp into its 2 ohm power range. On another note I have been beating the snot out of the sony explode stock location speakers with Bass Mechanic Cds. Man I think I may go deaf before those speakers go out. Not bad for 2 6.5s and 2 6x9s. I may say the looks I get are classic though I turn it down at stop lights. A beat up 89 accord bumping lol. Still the trans in the truck is taking longer then expected. I cant wait to start getting the old(is 93 considered old now?) farm truck into shape.
