Well boss amps have a good range of amps in the $100 and under. It would be nice to have a monoblock to simplify wiring. The power ratings don't seem bad either. Though I think I still want to get a Kicker sub. Everything I have read on them says they can take most anything you throw at them. Guess I have some more researching to do. No plans are ever set in stone.
but I could only afford it if I got it off ebay or find a refurbished unit. the ebay ones are probably refurbished anyway. What size is your box? Looks a little shy of 1 cu.ft. The box I want to build has to be able to be cover by the pull cover in the back. Also I plan on putting it behind the divers seat or maybe I'll put it in the center. I may just put the sub off a little longer and get the L7. Is your L7 a DVC 2 or 4. Just wondering because if I get the L7 then I will probably go with the same amp you have. I'll do a draw up of a box that fits the Kicker specs for a sealed box. Should leave a lot of space in the back.
