Pesky, persistent misfire
Regular Guy
Suncoast, Florida
Hi all;
I'm getting P0305 & P0316 codes.
I replaced plugs, wires and coil pack and ran some fuel injector cleaner about a month ago, which cleared it up until yesterday.
After a 100 mile road trip, idle became rough and the CEL popped back on.
What's next? I was thinking Crankshaft Positioning Sensor; am I on the right track?
'03 Ranger Edge 2wd
3.0l
129k miles
Thanks!
CKP(crank position) sensor wouldn't cause that.
CPS(cam position sensor) might but it would not be cylinder specific, i.e. 0305
There was a TSB for the 2004-2006 Ranger 3.0ls if yours was a late 2003 then it could apply.
http://ww2.justanswer.com/uploads/jmcdo28/2010-01-20_024443_tsb05-26-03.pdf
New plugs might have cleared it up for awhile.
Compression test on #4, #5, #6 might be best just to take the valve seat issue off the table.
Did you have a look at the old #5 spark plug when replacing them?
I would look at #5 now and compare to #4, if #5 is blackish then low compression could be the issue, but could be other things as well.
Thanks Ron; not being terribly mechanically inclined myself, I want to be armed with good information when I go to the shop.
Sunken valve seats are very very very common.
A static compression test won't show it, a running compression test will.
