Winger
- Aug 4, 2008
Does anyone know were you can get a replacement PCV canister. I believe that is what it is its the semi egg shaped cannister that press fits into the block right behind the Distributor. Then it has a hose that routes up to the upper intake. I've asked several parts stores and they keep giving me the same old generic pcv setup that you'd use on a valve cover with the rubber grommet. One parts guy claimed I had a late 87 motor in my 88 Ranger? I don't think there's any difference between an 87-89 2.3L.
Thanks
