Hey gents. Drivetrain is in, and all buttoned up. I’m in the final stages of getting this turd running.
non pats engine into a pats body. Yes, I knew this would be a bridge to cross eventually.
turn key, fuel pump primes. Touch starter signal wire to power, and she’ll crank/fire. Only fires for about a second, though.
I understand that a dealer will need to reprogram the pats to the ecu, could it be cutting fuel and ignition, or perhaps just fuel?
anyone done their own pats bypass? I’m not fixed on keeping pats if there is a simple solution, but also Ok with going about it the dealership way.
Thanks!
Thanks!
